Trying to decide if I should run what I have, buy am $850 new intake, or a $250 port job on the explorer intake. Is 350-400hp N/A possible with an unported explorer intake?
Totally not true. With the right porter.. they will support 400 RWHP easy. Definitely cost effective to port the explorer intake versus buying aftermarket intakes.. if your decide to go that route..look up Bigdogs porting for sure!There are several slightly different versions of the explorer style intake. I doubt it would support much more than 300 whp even with porting. Unless you want a stock appearing engine, an aftermarket intake is a more cost effective option and you would have room to grow. I would look for a holley systemax intake, which is one of the best efi intakes available IMO. You may also want to ask Tmoss about this. He has done alot of work on the explorer/gt40 intake platform and has gotten some impressive numbers out of them.
I’ve never seen an explorer intake make 400whp, unless nitrous was involved.Totally not true. With the right porter.. they will support 400 RWHP easy. Definitely cost effective to port the explorer intake versus buying aftermarket intakes.. if your decide to go that route..look up Bigdogs porting for sure!
"Properly" ported Ed? You mean grind on it until you cut through the aluminum , then use apoxy to fill it back in, then paint over it to cover up the bs work?No way are you obtaining 400 RWHP with a naturally aspirated 308 inches and any Explorer intake.
Buy a Holley SM2 and get it "properly" ported, not hogged out.
I agree 100% but this is a different build totallyMaybe read the OP's signature?
308 DART PRO1'S
TREMEC 3.73
Again for those in the back of the class room ...
You are NEVER going to make 400 RWHP with any Explorer intake in a naturally aspirated 308 engine...
You must work with some pretty hack porting shops! (PS: it's "E"poxy not apoxy.)"Properly" ported Ed? You mean grind on it until you cut through the aluminum , then use apoxy to fill it back in, then paint over it to cover up the bs work?
Why spend money on the SM2?
Because its a decent intake that needs no extra work to do what the OP wants.Why spend money on the SM2?
His first post states n/a, and his signature says 308ci.The question was..
" how much hp will an Explorer intake support"
Not how many cubic inches.. not blown or natural aspirated...
Man yall need to relax, no need get hostile.
The idea behind porting is stealth while looking stock. Or..you guy buy a $700 intake and look cute and make less hp than a junkyard intake. Its all up to you.
Fair enough. Hope it all works out for ya.Because its a decent intake that needs no extra work to do what the OP wants.
I get the whole stealth stock thing. I did it myself in the 90s and have inhaled enough metal dust to have a mining lung disease. I left the engine nice and dirty to make it look like a serious pos. Its cool when you want bragging rights, don't have money or a girl friend plus tons of time to kill, but these days I have more important things to think about with the 20 or so years I have left on this earth.
Why a Holley SM2? If you have to ask, time for you to buy a Honda and sell the Ford.
Great thanks, I guess it's not as much of a restriction with air being forced through.I made 510 rwhp with unported explorer intake and a D1SC Procharger on a 306, with TW170 Pedestal Mount heads. 1.6 RR, e303 cam and professional products throttle body.
When it finally blew up, I took the throttle body off to find a stock throttle gasket. Lmao.
