1 - 20 of 109 Posts
Stock short. 5.0
Edlebrock e street. 2.02
Ported by me. 284cfm up from 234cfm stock.
Have to cc heads yet there over 180cc
Angled milled .0120 11.2 comp . .039 squish
Ed cam. 7000 peak.
China funnel web. Epoxied up center runners.
Still working on outer runners. All runners flowed on heads
750hp holley
Long tubes. 1 5/8
Have a victor junior to. But I don't think I will need it. Just need valve springs. Have everything else.
Was going to use my gt40ps Ed. But found a deal on some estreets.
399
Stock short. 5.0
Ed cam. 7000 peak.
750hp holley
Long tubes. 1 5/8
Did you flycut the stock pistons? If not is the cam spec'd to work around the valve clearance with 2.02 valves on stock pistons?
Yes flycut. Ed had his choice on lift
Some other guy on here around 400 on eng dyno and mine is much more thought out
Holdner can make 425 with worse cam and intake
And hardly any compression
400.
Stock short. 5.0
Ed cam. 7000 peak.
750hp holley
Long tubes. 1 5/8
Sounds like to me that bolting on a vortech would have been easier .
  • Like
Reactions: Foot Hill
1985 Mustang GT
Holdner also runs long tubes with headers extensions only, low temps, no accessories, E water pump, if we are talking engine dyno I can agree in the car I will not.
Is this what you will be doing?
There are way too many head units for bubba to choose from there is no way there is a Centri in his future.
Lol. It would make for some interesting reading.
Discussion Starter #16
Of corse engine dyno.
Heads have good coefficient discharge for a sbf.
Did modern 4 Angie vj alot of porting.
Low Temps.on dyno,glory pull. Nothing wrong with that. Assuming the Temps aren't ridiculous low.
305 to the tire. Nobody knows if you screwed the pooch when you ported the heads, so I am guessing low.
1 - 20 of 109 Posts
