I’ve had valvetrain clatter on this engine through 3 different sets of heads, 4 different set of rockers and 3 different sets of hydraulic lifters. This build has AFR 165 heads 7/16 stud, Comp Ultra Magnum Pro rockers, FMS H lifters and a semi conservative Ed Curtis cam. Pretty decent parts. Engine runs really great, but the valvetrain noise is a bit annoying. I use 10w30 conventional oil.
On assembly I measured carefully for pushrod length and got a nice narrow, centered pattern with a 6.40 length. I adjusted to zero lash on base circle using the “spin it 90* and zero lash all” method. I did 4 complete crankshaft rotations stopping every 1/4 turn to ensure I had all at zero lash and no preload in the lifter cup. Then I went around and gave each lifter 1/2 turn preload tightening the polylock with it on the last little bit of the turn. No unwanted contact anywhere that I could see.
That all sounds right....right?
So today I have some free time, I figure I’ll pull the upper and valve covers and check my valve tip wear to confirm proper pushrod length, and assuming everything looks ok give the lifters another 1/4 turn preload.
Any other suggestions before I dig in? I’m half-assed wondering if I should just loosen up all the rockers and start over again using the more traditional “exhaust open-intake closed” method of zero lash, but it should end up with the same result.
I’m not expecting complete silence, but trying to get it as best as I can.
And it is definitely valvetrain, not header leaks etc.
