1 - 20 of 27 Posts
Rebuilt 306 ,aluminum heads 2.02 ,190,60cc,fcam,smogdelete , ... Car will start but not stay running unless i keep the throttle open a bit..cant even get the timing lighton...found compression stroke...put balancer at 0 roter and magnet inside line up at 1130ish..starts but won't t stay running and run really rich...pretty confident everything inside is right. Look for info but so many possibilities, just wanted some fresh input...its a 1990 fox lx...thanks
Trying turning the distributor to advance the timing a bit. Your timing could be too far retarded.
I just went through that same thing and it wouldn't stay running initially. I turned the distributor to advance the timing and it started and idled.
Iv have done that...multiple times..the further I advance the quicker it fires but still won't run....
Here’s the easiest way to get the timing spot on EVERY TIME.
Instead of putting #1 piston @ TDC & dropping the distributor in do this.
Put #1 @ 10° BTDC on the balancer & drop the distributor in with the rotor pointing @ #1.
Put the timing light on it with the SPOUT out & it’ll be spot on 10°.
Do you have the throttle body screw set properly?
Did you check for possible large vacuum leaks?
Assuming this is a factory computer?
Are the o2’s plugged in?
Factory computer, o2s are in and plugged,don't know about leaks yet cause won't stay running..was unaware about the screw...stock tb..just small upgrades on the rebuild..and I have now tried 10..6..and 0..with the spout out..will fire but not stay running ..runs rich
What balancer do you have?
Is the fuel pump running when the engine starts?
that does not confirm pump is running
are you saying you can keep it running until it reaches operating temp?
Discussion Starter #11 (Edited)
No I hear the pump prime when I turn the key and if I hold the pedal down just a bit it will stay running but not very well and I smell fuel..runs rich..as soon as let off it will die..have not been able to reach operating temp
Correct firing order?
can you keep it running?
Prime has NOTHING to do with pump in RUN or crank
Also you have NO idea if it is rich, without knowing commanding fuel
so lets stop eluding to the fuel smell
Distributor rotor turns counter clockwise, so just double checking your firing order is right. Sounds like timing or firing order issue
check your maf sensor wiring
check tire pressure!!
NEED to be lower
Discussion Starter #20
Very true...ok so I found a couple vacuum lines that were not connected..got it to run and idled..when I put the timing light on with the spout out it way avanced...like 20...if I turn it to 0 or even 10 it dies and won't start...
1 - 20 of 27 Posts
