41 - 60 of 86 Posts
Discussion Starter · #41 ·
Discussion Starter · #42 ·
Wastegate setup. Pulley for what ever boost you want to happen at what ever down low rpm you want and dump the excess boost before running it through the intercooler. No sense cooling air you won't use anyway. If you pulley for 30 psi at 6000 you will have 15 at 3000 and 10 at 2000 and 5 psi at 1000. You'd hit 8 psi at 1600. Once you hit your target, you can more or less hold that psi. In principle it's the same thing turbos do.
That's interesting. I never heard that before.
I was just thinking about this for my T Trim, out of fuel around 18lbs... so I'm looking into getting a wastegate for 18psi.. and throwing the 23lb pulley on.
Should come in way sooner and then flatten out through recline. Not alone of examples on foxes though.
There was an article years ago in MMFF about it.
EDIT: I found it!!
My search turned this up too. It's GM but the principle is the same.
2000 Mustang GT
Centri is a simpler install, you don't have to touch the exhaust system at all, and don't most turbo kits want you to go with a tubular K member?
Centri cam break the crank snout. Pros and Cons. Pros and Cons.
Is this just a cast crank concern? I have never really heard of this on forged ones outside of hardcore applications like cogged setups.
Discussion Starter · #48 ·
EDIT: I found it!!
Thanks!
Discussion Starter · #49 ·
That's another added cost. I don't have an exhaust. I bought this car bone stock. I do have a tubular K member though.
Discussion Starter · #50 ·
This is a concern along with bracket flex and belt slip.
Discussion Starter · #52 ·
Stock block? Si Trim Vortech, 3.33/8 pulley combo, Snow meth, and call it a day. Don't Bubba2 this thing.
Thanks. No Bubba2 here. Keep in mind that I'm considering a blower but I have a turbo as well. All of the advice is helpful.
Happens when chasing belt slip. Crank snout ends up side loaded and breaks eventually. Stock crank problem as far as I've even heard about. 4.6's don't seam to suffer the problem.
Discussion Starter · #58 ·
I made my own manual tensioner and it reduces the amount of tension you need to solve belt slip. Post is old so the pictures don't work anymore.
41 - 60 of 86 Posts
