Have a weird QH issue, I was live tuning a param and suddenly the car started running rough. I cycled koeo and notice the fuel pump was constantly running, so I thought corrupt bin.
Uploaded a old known working bin and pump still stayed on. Disconnected the USB and koeo and pump primed & turned off as normal.
But, reconnected USB, koeo and the pump stayed on! Verified bin was ok, did it again but accidentally pulled the USB out while reverifying, reconnected and now pump primes as normal koeo. Weird. BUT now the car runs really rough when it goes closed loop! Car was running good before all this, same time, just tweaking MAF curve.
Any way to check if the QH is truly 100% working aside from verifying the bin? Is there a way to do a hard reset? Or a mode to clear everything
