1 - 12 of 12 Posts
Ok guys I have an 87 coupe with a 308 some kind of Aftermarket forged pistons. Edlebrock performer intake 52lbs injectors 340 pump an -8 feed line an-6 return ..and pro m efi system and pro m blow through 80mm mass air 75mm edle tb .gt 40 3 bar heads and a percision 7678 76mm turbo .a comp cam xe 274 cam .im trying to get the most out of this combo. I bought the car this way and trying to get it up and running .I have added some of these parts .like the pro m efi system my main question is what kind of power will I be making how much boost on the safe side .should I go ahead and get some better heads if so recommendations? Better cam like a blower cam or what cam would be best .Trans is a pa c4 full manual reverse valvebody 3600 stall converter ..plz help ..im sure I left out some info .any questions just ask
Is ur trans built. Is ur rear built.
That 80mm may will give u issues qt the higher end.
Comp cams custom grinds are what u want call n tell them ur plan.
What fuel type 93 e85
Sent from my SM-N975U using Tapatalk
Trans is a built pa c4 full manual valvebody .good for 1200 hp.rear end is built 327 gear .welded tubes.strange axles .supposed to be able to handle 1000 hp .how about the
93 octane
As far as ur cams give comp cams a call to verify if what u have will be doable for the power ur trying to make. The heads seems ok to me honestly. For a boosted application some want boost quickly while others want boost in the highs 6k rpm range. Thats how my setup is. I built my motor and all to support it so around town I see 3 to 7 psi. I didn't want a all out track car so that's why. I am pushing 14 psi putting down 612 601 tq thru a 4r70w in my 01 GT.
For your setup I can see even higher do to fuel setup u have. Now u need a tuner that can dial it all in.
Fuel system is optimum for that set-up . I would be looking for at least 60's or 80's for that size turbo and two 340 fuel pumps . Just my 2 cent
Should I down size the turbo im wanting a fun dependable street car .that will live for a while..recommendations on turbo size and brand that won't break the bank
On3 makes a 70 mm turbo that people have had great success with. Good for 500rwhp
I'm very new to the turbo game .im looking for a good turbo 58 to 66mm t4 that will put me in the 500 to 600 hp range and will live for a while
1 - 12 of 12 Posts
