I am installing a new set of FMS gears. The rearend does not have the stock gears, so I will need to find the proper pinion depth. If I understand correctly, I am supposed to install the pinion bearing and then put the pinion into the housing to determine pinion depth and the number of shims to use.
Once I determine the amount of shims needed, what are the backyard mechanic ways to remove the bearing so that it can be installed a second time?
Thanks,
Thanks,
