I did a 5.0/ AOD transplant in a 68 mustang using a 91 GT donor with AOD and a9P computer and AOD O2 harness. I cant get it to start. I grounded pin 30 to the battery instead of starter because after reading threads here I was petrified to fry my ECU. Wiring diagram says pin 46 is a ground for sensors and also needs to link with pin 30 to allow car to start. Do I just ground both together or do they need to be switched and the unswitched after starting. I am lost
you the function of the circuits wrong
yes
just requires the correct amount motivation
Seems like that's already been established since he can't get it started.
I'm not sure if it's in here but tmoss has a lot of information on his site.
Pin 30 is a monitor
in auto>connect 12v from crank on ignition switch
in manual>its spliced to the sensor ground circuits that goes to pin 46, through the clutch and gear switches in parallel
do not mix them up.........good enough.
