Will it mount as intended?
  • No
    Votes: 0 0.0%
  • Other
    Votes: 0 0.0%
Hey all, just have a quick question I couldn’t find an answer to, hoping y’all can help. I have a 90 GT with a turbo coupe rearend that’s lowered maybe an inch. My question is, does anybody know if a maximum Motorsport panhard bar kit will bolt up as it should/would with the stock mustang rearend? Thanks in advance.
P.S. I have created a poll, so if you just want to quickly answer, there ya go. Thanks again
Discussion Starter #2
Well I’ll just close this one out and give the info I’ve received for anyone else in a similar situation. Got an email reply from MM and they ensured me that the Mustang panhard kit WILL work with a turbo coupe rearend.
Just to clarify, the TC housing is the same as the Mustang. The axle shafts are longer. With that said, the MM PHB bolts to the axle housing where the DS shock mounts (an integrated shock/PHB mount) and other end bolts to the MM chassis mount on the PS. This is the same design for all Fox chassis, SN95 and new edge Mustangs running an 8.8 stick axle.
