Just bought stock 1973 Q code (351c4v) mustang convertible. I have read much about the 1970 closed chamber heads over the open chamber heads I presently have. Is there any advantage and can I swap heads to the cc without changing pistons? Assuming I can do it (I am not sure if the 1973 pistons are compatible (clearance wise) with the 1970 heads) is it worth the effort? What will I gain and what will I lose? Stock 351c 4 speed with 3.25 9" ls rear.
