Discussion Starter #2
does no one not have a close tune to my set up?? 302 hci 60 lb seisman deka 60 lbs 3 bar gm map autometer 02 wideband i plan on going with a 0n3 70 mm turbo set up also thanks guys you can send some calibrations to my my email [email protected]
It's really difficult to provide an e-mail tune for a speed density system, which is likely why you're not getting any responses. You can get a rough startup tune using the base calibrations that AEM provides. If you're having trouble with those, I'd suggest you find a local tuner to help you out.
You'll be much happier in the long run.
yeah... start with the base 2 bar map, and re-scale it for your injectors. that should at least get you started so you can get the car to someone
