I have had outstanding results with the AEM system in my car for the last two years until I started getting timing errors all of a sudden. After doing the research, a lot of people were going to the EPM system with coil on plug. I just finished getting my car running with the new setup and it runs like never before. Outstanding idle quality and throttle response with smooth crisp pulls at the track so far. The AEM system has so many options such as boost control, nitrous control, two step / multiple rev limiters , individual cylinder tuning, internal and external datalogging etc etc. So those of you who trash talk the system, you obviously were doing something wrong or had the wrong person tuning it.
I am glad the AEM is working out for you. As far as doing something wrong, why is it almost everyone has timing errors? Are you saying you or your tuner did something wrong? Trust me I did everything. I bought a BRAND NEW NOS harness for my car, BRAND NEW FORD EVERYTHING dist, grds etc... I was going to switch over to a crank trigger but said screw it I'm done. The timing error issue is a real one with the AEM. AEM says if everything isn't "perfect" the AEM won't fire. That's BS IMHO. No other system has that problem, why does AEM????
The AEM does have a lot of features but there are other ECU's that do the same and more.
The AEM crowd is basically looking for a plug and play setup that is reasonibly priced, that's why I bought it. But by the time you buy the coil packs and EPM the price and install are just about what other S/A ECU's cost.
You car is flat out flying!!!!! The motor in you have listed in the one you are still running? How much does you car weigh?
Also let me ask you this because I am curious: Why did you go the EPM route over a crank trigger setup? The crank trigger is superior IMO.
