21 - 39 of 39 Posts
Discussion Starter #22
Before I bought one, I'd go through the wiring one more time. Heavy red has power all the time? Heavy black to good ground? Small red has power with key on? Small black to coil negative? Small orange to coil positive?
If all of that is good, grounding the white wire should produce spark like described above at the coil wire. Coil wire needs to be connected to the coil. Other end metal terminal 1/2" from ground. Every time you ground the white wire, it should produce a spark.
Even then I would still try to borrow an OEM coil because your msd coil could be good. Wont know until the 6al is tested with a known good coil.
I have the coil wire on the coil and the other of the spark plugs 1/4 away from a ground and I'm tapping the white wire still nothing
Shouldn't be any spark plugs involved in this test. Just the other end of the coil wire 1/2" from ground and by other end I mean the metal part that snaps on the distributor cap.
Right.
Do the same test with a known good coil. Factory stock coil is the most reliable if you know someone that has one laying around. Doesn't have to be anything special.
Discussion Starter #28
Ok I'll ask a couple ppl tomorrow if I can borrow one and ill let you know what happens and I thank you for your time and help I really appreciate it
Discussion Starter #30
I have a new coil and I did the tests again and I still have nothing my msd 6al box only flashing 5 times and stops
What do you mean by flashing 5 times? What is flashing?
Ok. That's just the rev limiter verification. if you have done all the tests correctly and the coil you borrowed is good, this means the 6al is bad.
Curious, where are you?
Discussion Starter #34
I'm from Vancouver bc my 6al is new out of the box
So can I ask does the 6almsd box need tack signal
It doesn't need tach signal to operate. You can completely disconnect the tach signal (gray wire) and it would work provided its wired correctly. New doesn't always mean good but I would be surprised if it was bad out of the box.
Discussion Starter #36
Ok I'll buy another one and hope it's the problem I have the gray wire hooked up now think that can be the problem
Discussion Starter #37
Hey 1st off I'd like to thank you for your time and help Ii just went over everything on my car and I now have spark I used the new coil thanks alot
Great news! Glad it's working now.
hold on.
you stated you already tried with a good known coil, and no spark
now it works with another coil...........what?
21 - 39 of 39 Posts
