21 - 29 of 29 Posts
what are the long term fuel trims?
Discussion Starter #22
Still trying to figure out all of the definitions for the gauges on the Dashboard.
Guessing that long term fuel trim is LTFT, which I don’t see on the Dashboard, but it might be in another area that I saw once and need to see if I can figure out where.
Ken R
also known as kamrf 1 and 2
Discussion Starter #24
Okay
Full throttle TP 4.78, rpm 5100, LAMBSE 1&2 0.805, KAMRF 1&2 1.00
Deceleration TP 0.00, rpm 2200, LAMBSE 1&2 0.953, KAMRF 1 1.082 #2 1.086
Idle TP 0.99, rpm 696, LAMBSE 1&2 1.008, KAMRF 1 1.082 #2 1.086
Make any sense to you?
Ken R
kamrf will be 1 at WOT
you want all driving in closed loop, non WOT
at idle you are slightly lean
you want to to see load and rpm cells
Discussion Starter #26
Are you talking about the load and rpm on the dashboard or could it be something that I would find in scalers, flags, tables or functions?
I have a question on a different subject, but is still relevant to tuning.
If I change from the stock 65mm throttle body to a 70mm throttle body, would it change anything in my tune?
Thank you for all of f your help.
Ken R
adaptive fueling corresponds to a cell in a table based on load and rpm
therefore you need to be in each cell
if you raise the rpm from idle and watch kamrf you will see it change as you traverse the cells
new TB will require you to measure the amount of it flows when closed
you then enter that value to the ithbma scalar
its in the efi writeup, as far as procedure
Discussion Starter #28
Thank you
i should have noted, its imperative that you have no air leaks when you measure TB airflow
its key that its accurate, to get transitions from open throttle to closed throttle and stable idle rpm
21 - 29 of 29 Posts
