I've searched, and searched, and searched multiple forums on the March Ram Air system trying to find any hard data as to whether or not it actually works in a 1/4 mile environment. What I mean by "work" is add E.T. or MPH to a 1/4 mile run. Everything I find is just people complaining that the scoop picks up dirt/pebbles/leaves/water and no one actually testing the system to see if it actually makes the car faster in the 1/4 mile. I really want to know the March system doesn't add any performance vs. drawing air from the inner fender or putting the air filter in the inner fender.
Here's why I'm curious if the system actually works. I've been running just the box portion with a 9" conical K&N for a couple of years.
I tested the March box with a 9" conical K&N vs. the stock airbox with a panel K&N at the track, on the same day, and on back to back to back to back runs. The March box and conical K&N are consistently worth .1-.2 seconds and 1-2 mph through the 1/4 mile on my setup. I attribute that to the larger surface area of the conical filter more than anything else. Both setups are drawing air from the same location through the same size opening. The car also ran exactly the same times with the March box covering the conical filter as it did with the conical filter open in the engine bay.
So from testing I know the K&N conical filter in the March box benefits my setup. Now I have the scoop and hose from the kit sitting in my garage. I'm wondering if I would see any gain in the 1/4 mile from hooking the scoop and hose to the box? The only way I can see the scoop and hose providing any gain is if it somehow adds a tiny amount of pressure to the air box. With the number of bends air has to navigate through the scoop and hose to get to the air box any "ram" effect is probably negligible. Does anyone have any hard evidence that the scoop and hose actually improve 1/4 mile performance vs just the box sucking air from the inner fender? If not I guess I'll have to be the guinea pig next time I go to the track.
