Got a Sony mex bt100 that has the 160w class D amp built in. Have 12ga direct to battery powering it. Reused the mach460 tweeter wires for Rockford component fronts. I sealed the backside and used roadkill foam behind the speakers in the door. added some dynamat where possible around the door. I'm getting terrible bass performance compared to stock in the doors. Turn vol upto 50 max, everything is loud and very clear, but bass barely vibrate the doors, muted, non existent bass while car is running. No boom. My truck+stock paper speakers sound 10x better. Is there anything specific with reusing the mach tweeter wires? Checked for phase issue with a meter all ok. Ideas?
Mach amps are removed, so only Mach stuff is tweeter wiring.
