1 - 20 of 135 Posts
Hello. I have a 363 stroker that seems a bit under power. It made 366 rwhp @6300rpm on a dynojet total timing being about 28 degrees
The combination is: 10-1 compression
Tfs 205 11r heads ootb
Ed Curtis hydraulic roller
Edelbrock vic jr carb style efi intake ootb
42lb injectors
90mm accufab tb
1 3/4 longtube headers to off road x pipe
The car seems to run ok which is why I can't figure out what I could be doing wrong. Any ideas? I tried to include as much info as possible. Thanks
Aode with a locked converter. No track times. The dyno was during the tuning
Seems in line... you made 1rwhp per cube
Like a 300rwhp 302.
Now go strap a YSI on it with a fuel system and make 900s
You should at least be making close to 450 rear wheel horsepower. Something, somewhere is wrong. What is the tuning software?
Timing seems really low. I could see 28* if he was running 10 psi of boost.
  • Like
Reactions: FlamedHatch
Lots of horsepower lost due to a horsepower robbing AOD combination and we are talking rear wheel horsepower on a chassis dyno. Add an estimated 80 horsepower to your RWHP so you have 446 horsepower at the crank. Right where it should be.
or more
Even through an aod, 366 is pretty low.
Tough to give any educated guess with zero cam information.
28* isn’t out of the ballpark for an 11r head, I’m assuming you tried 30-32* as well?
Like said above, drivetrain will eat some power.
If you still suspect being down on power, have you done compression/leak down tests? What were the results?
Discussion Starter · #14 ·
Same car same dyno same trans made 262 rwhp 287lb ft with Edelbrock performer heads b303 cam and cobra intake on a 91 stock bottom end. Sct chip. Lidio tuned. Not an aod its an AOD-E with a locked converter during the dyno pulls in 3rd gear. The cam is an fti custom cam. I have not done any leakdown or compression tests yet. Just trying to get some ideas
Discussion Starter · #15 ·
I only did 28 degrees because I thought that is what those heads liked. What is ideal for these heads?
Discussion Starter · #16 ·
What were your results with your 347 off nitrous?
'87 Cougah 428W - ⚡Cougar7.0⚡
28 might be fine, though it's common to vary timing during a Dyno session to see what effect it might have. Also confirms that your pointer is accurately located. Def seems like something is amiss with that HP number. Get a mph from a dragstrip if you can to back up the Dyno number.
  • Like
Reactions: Leadsled Coupe
On a built 347 back in the day, one degree of timing made 30 more rwhp. The next degree added 15 rwhp and one more added another 10 rwhp. Another degree added next to nothing and the next degree lost 5 rwhp. We backed it up 2 degrees and called it good. Some engines are sensitive to timing changes and some are not. But 28* total is low, even for 87 octane pump gas. With 93 octane that engine "should" like 32-34* of timing.
I run 24* at 21 psi of boost with E85. I know it is not a direct comparison, but still...
At 30* it made 422whp through an a5 trans with no nitrous. That was before I put the fti cam in, so it would probably be in the 440 range now - which is backed up by the mph it runs in the 1/8th.
What’s the duration numbers on the cam?
USAF retired
A chinese knock off intake, no porting? The outlets to the heads are tiny on those, made for stock size ports.
  • Like
Reactions: 65fasback and tmoss
1 - 20 of 135 Posts
