Got in the truck the other day and it wouldn't idle and was progressively losing power. Came home and noticed that the EGR Valve Control Solenoid was busted (cap was missing). Replaced that, started it up and it idled just fine. Problem solved? Loaded up some stuff to run some errands and took off. I could barely get out of the driveway, it was losing so much power, came back and parked it.
Fuel pressure is about 38 lbs.
Fuel filter has about 10k miles on it
Air filter was recently cleaned (K&N)
I don't hear any vacuum leaks
Not throwing any codes
Thoughts?
Thoughts?
