Okay guys, post up pics of your truck with your year, build number and mod list. I'll start. 2001, #6257 of 6381. Born on 8/15/01...
Mod list.
Engine/exhaust-
Ported and polished throttle body
Amazon tuning/Billetflow 2.80/2# upper pulley
LFP 4# quick change lower pulley
Metco pulley snout cover/bolt
AEM Brute Force CAI
LFP oil seperator
LFP EGR delete
Hedman shorty headers with Percy's header gaskets
Modified factory midpipe
Dual Flowmaster 40 series mufflers
Stainless exhaust tips
Brakes/Suspension-
Eibach front coil springs
Hotchkis 2 leaf rear springs
Belltech Nitroactive drop shocks
Energy Suspension poly swaybar bushings and endlinks
Rear lowering shackles
Rotorpros drilled/slotted rotors front and rear
Hawk ceramic brake bads front and rear
18x9.5 American Racing Torque Thrust 2 wheels (discontinued)
Interior/Engine management-
Black carpet
Leather seats with factory SVT inserts retained
Aeroforce Interceptor Scan Gauge in Autometer steering column pod
Tuned by me with Sniper Special Forces tuning software.
Exterior-
Black DEPO SVT reproduction tail lights.
#400, 4/19/1999 Just a K&N cai, drag radials. Just put about $350 into her via a new set of fuel pumps and replaced the Motorcraft battery from 2002!
here's mine
Year: 2002
Build number: #565
Build date: 12/5/01
Mods:
Engine and Engine Bay
1. stock long block (70k mile takeout from another ‘02)
2. super charger belt drive = 8# lower (metco two piece), stock upper, metco aux idler bracket with 100mm idler on drivers side, 90mm idler on passenger side, stock tensioner (with limiting tab deleted)
3. 60# injectors (EV1 connectors)
4. bed mounted 3 gallon I/C tank, ¾ inch lines, Jabsco pump, stock I/C heat exchanger
5. “Because Race Car” ported Eaton and Plenum
6. JDM 108mm inlet tube (SCT BA2400 MAF electronics) – AFE 15” Air Filter
7. Magnum Powers “Big O” Throttle Body
8. stock exhaust (pacesetter Long tubes, w/ 3 inch exhaust coming)
9. Dyno Tuned by Lee @ Blankenship Tuning and Performance LLC = ? rwhp @xxxx RPMs / ? rwtq @ xxxx RPMs
10. braille battery / aluminum battery hold down box
11. Relocated power steering reservoir
12. A/C Delete accessory belt drive (A/C components unbolted, but included)
13. dual 16inch electric “pusher” fans, (unknown controller)
14. twin walboro 255’s / stainless Y-fitting / gates hoses / BBK adjustable regulator and ’97 rails
15. J&S Safe Guard / Vampire engine protection system – steering column mounted indicator gauge
16. “Blacktop” 3/8 inch mid-plate / turkey pan aluminum spacer
17. JDM 3/8 inch pholenic plenum composite spacer
18. DMR bracket for the Barometer
19. NGK TR6 spark plugs
20. stock 180* thermostat
21. a couple of “air flow” mods that I don’t talk about, LOL
22. DELETED = EGR, Evap, Cruise Control, additional vacuum box, stock battery box, windshield washer tank and lines, under-hood I/C tank, heat shields
Suspension
1. Hotchkiss rear leaf springs
2. Hotchkiss front coil springs
3. Hellwig front and rear sway bars
4. JLP 54" long bars
5. Competition Engineering drive shaft loop
6. Hotchkiss TVS spec bilstein shocks
Transmission
1. PI 2600 stall converter
2. JLP valve body
3. F250 transmission fluid cooler (stock radiator flow thru / heater bypassed)
Interior
1. stock seats
2. no radio currently
3. Cruise Control Buttons delete trim waiting to be installed (also have brand new buttons)
4. a/c unit disconnected but in cab components still in place
5. chrome pedals (unknown make/model) – about to be removed
6. J&S Vampire knock detector gauge (in steering column pod)
Exterior
1. tinted windows / windshield brow
2. Street scene grills (faded black) – about to be swapped for ’99-’00 Lightning grills
3. after market (believed to be DEPO) black head lights and tail lights with stock third brake light
4. 03/04 rims with 295/45/18 nitto 555's
5. front wheel well liners deleted
6. trailer hitch deleted
7. factory spare tire and spare tire winch deleted
Pictures:
engine bay now that I own it (and have seen it, done a couple things)
svtphillip said:
65fastback2+2 said:
2002 Lightning, dont know the build number yet.
Mods so far,
JLT Cold Air
High flow cats with flows
Belltech springs, spindles, shackles & hangers.
Ultra Clear headlights
Smoked Taillights & third brake light
Black Billet Grilles with svt emblem
Boss 22" 335 Wheels
Tri-Fold Bed cover
