1 - 20 of 51 Posts
I was wondering if anyone has real work dyno numbers with the 11r series of heads from trick flow on their 351/357w. I’m curious to see what the car is gonna put down once it’s back from paint and I get the drivetrain stuffed in it. Combo is:
stock block 351w (.030 over)
Stock length forged scat h beam rods
Kb hyper pistons
cam: hydraulic roller
duration 23x, 24x @50 lift .6xx .6xx 114 Lsa
Tfs 11r 205 heads with 1.6 rr
Tfs r series carb intake converted to efi
Holley 1000cfm tb
42lb hr injectors (might go more)
10.3:1 compression
1 3/4 lt headers
expecting to spin it over 6500
anyone have good numbers with these heads?
1989 GT
That’s about where I expect. I was hoping around the 450 mark
Your LSA on NA would have been better around 112. You also could have run a bit more compression.
make sure you are using a windage tray
That 450 is probably optimistic.
In the cam sheet I emphasized being able to run power steering and brakes, I’m assuming the 114 lsa was to compensate for the vacuum requirements however I’m far from a cam expert.
I would have to agree with STANGDAWG on his post - are you giving up cylinder pressure just to run accessories that need vacuum ? Fine edged sword there - your call no doubt but each of us has a different view on what is "street-able" - best of luck with your build !
It’s gonna be a 100% street driven daily driver haha, power brakes, ac, and power steering are a must!
You definitely could’ve kept a tighter lsa while maintaining good vacuum for accessories. Sometimes it’s better err on the safe side though.
If the exhaust system is good, 420+ is doable.
  • Like
Reactions: Cclaro
My engine is very close, 347 with AFR 195’s . CAM is also close spec wise but I have a tad less duration and a little more lift with a 112 LSA. I made 387hp/403t rear wheel all in by 6000 rpm. You will build good cylinder pressure down low due to your small overlap. Spinning to 6500 won’t make much difference, It’s a really good street combo and should be fun to drive.
Any recommendations on a decent set of mufflers?
Discussion Starter #12
What intake are you running? Exhaust set up?
Discussion Starter #13
Would using a .027 head gasket to bump up compression to around 10.3:1 be worth anything?
I’m running 1 3/4 shortly headers with 3” connector ( chopped off the ball joint) that transitions to a 2.5” H pipe and 2.5” all the way back. Intake is RPM II with a little work done to the lower. I also run a 70mm Accufab TB and 36lb injectors. Static compression is 9.8, dynamic is 8. Tuned with Holley Terminator X.
Discussion Starter #15
How was the install on the terminator? Are you running ac by any chance with it?
Holley install was straight forward, lot of info out there on installation. I do run A/C and power steering, although I run an updated compressor that only eats ~ 5hp and is good to 6000 rpm. FYI I also run a modified automatic with a 3000rpm converter. Last, my engine was balanced at a bob weight of ~ 1550 grams so the light weight stuff made a difference.
Discussion Starter #20
Kb hyper pistons
duration 231, 241 @50 lift .600 .600 114 Lsa
Holley 1000cfm tb
10:1 compression
1 3/4 lt headers
It’s gonna be sent through a t56 mag as well^^
1 - 20 of 51 Posts
