I seen that a lot of posts where the injectors for the 03-04 Cobra were not recommended for any other vehicle because the spray pattern was setup specifically for that car. I believe it was the angle that the fuel sprayed out of the injector or something similar to that. That's the only car I've ever heard of that had a specific injector like that. Since they are both supercharged 4v's though I was wondering now if the GT500 injectors are the same, or if GT500 injectors are ok to use on a non-supercharged 4v, 2v, or 5.0? Thanks
why would you not buy new KNOWN to work injectors for your vehicle?
its a aplit pattern injector thats why the orientation of the injectors is important on the 4v.
As stated get injectors that are ideal for your specific needs.
I don't need injectors, I didn't mention my vehicle at all, I just like to learn as much as I can. Thanks
