I know a guy here in central florida that you can send the computer and he turns it off on the bench and sends it back, much cheaper than buying the hand heldThanks for the replies. I'll check around the transceiver wires further. I did find that the ground wire that goes up to the lock tumbler wasn't making good contact. Fixed that and thought I had it whooped. Nope. I did the 30 seconds key on in run position. That worked once a few months ago. I'll look around again. Gotta be something simple because sometimes it works like a charm. If I could just get it to work all the time or disable it......
My local dealer, the only one within 50 miles, told me with a smile that there is no way around the PATS.
