Try as I might my Googling abilities have failed me. I've been down the rabbit hole of blow thru carbs (a research/knowledge thing) and I see this part in a lot of metering blocks, but I can't find a name for it or confirm it's function.
I suspect it allows the vent tube "signal" to pass through while inhibiting the fuel from easily going through vent passage.
Can any one confirm?
1064480
A baffle...... DUH!!! I could not come up with a name or term that brought that part up in a search. First result after "Holley Baffle" is a link to Holley for that exact part. Thanks.
And it does combat fuel slosh issues. Appreciate the assist.
