I recall reading several times over the past few years where some members here had wired their own relays and timed relays to control the electric pump and fans for a cool-down period.
For those that have done so, did you use a high amp timed relay, or did you have a high amp relay controlled by a low amp timer "up stream"?
Thanks in advance
Thanks in advance
