Back agian,
1. Disconnect the battery
2. Take apart the 10 pin connectors.
3. Get a small nail and slightly crimp the female side of the connectors, this will help tighten the connectons. Do this on the complete assembly.
4. Put dielectric grease on the male side of the connectors
and reassemble.
This is the fix for a stuck/high/surging idle. Example: You pull up in the driveway or to a stop light with the clutch in and the car idles it self up to 2K or 3K rpms and then stays there, then finaly drops down when it wants to. Or, your driving down the road, push the clutch in, and the car stays at whatever rpm you were at when you went to make the shift for more than a sec or two.
The 10 pin connectors are black and white plastic connectors that go between the main wiring harness and the fuel injector harness. They are located at the firewall end of the intake. I will try to find some pics and post them.
And you all thought this thread was dead.
Wes
EDIT:http://66.96.130.106/archives/2002/01/tenpin/
EDIT:Cleaning TB and IAB
EDIT(1/18/03) There is quite a debate about setting the tps at .98v or .97v or what ever, well. Set your voltage at .93v and enjoy. The info below is being posted because other than the voltage value given, it is pretty much dead on.
How To Adjust TPS
"Muscle Mustangs & Fast Fords"
April 1993
The throttle position sensor is one of those things that falls
into the category of "computer stuff" that makes a big difference
and is easy to deal with, but average people like us would never
know about. Without the proper adjustment, the throttle position
sensor (TPS) will give the computer a false reading as to the
exact throttle opening. A false reading will limit wide open
throttle performance (something we definitely don't want). A
voltage reading must be taken using a digital volt/ohmmeter
(DVOM) with the Key On/Engine Off and with the Key On/Engine
Running. A Radio Shack DVOM, part No. 22-185A, works well for
this job.
The TPS is located directly on top of the throttle body and is
adjusted by loosening the two phillips mounting screws and
swiveling the sensor until the highest reading is found. It may
be necessary to elongate the holes with a small file to achieve
the desired reading.
The spec range for Key On is from .88 to 1.0 volt; shoot for the
.97 to .99 volt. With the engine running, the voltage should be
no higher than 1.05 volts.
Incorrect Throttle Position Sensor (TPS) voltage will result in
reduced performance. The best way to take a TPS voltage reading
is by using two safety pins through the wires coming from the
sensor. The positive lead is attached to the green wire, while
the negative goes to the black wire. Always ground the meter
through the sensor's black wire. This gives a direct, and more
accurate ground into the computer.
and reassemble.
Wes
How To Adjust TPS
April 1993
this job.
