1 - 8 of 8 Posts
1061637
1061638
1061639
1061640
Stock block 306
Top proline (rhs) cylinder heads with arp head studs. 180s, 58cc combustion chamber, 2.02/1.60 valves, comp cams beehive springs with locks. Comp ultra gold roller rocker arms (stud mount), comp push rods and guide plates, comp lifters, F cam
JE pistons
Eagle I beam rods
30lbs injectors with matching pro M mass air flow
Edelbrock performer rpm2 upper and lower intake with spacer to clear tall valve covers
ZEX wet nitrous kit (125 shot)
Walbro 255 in tank fuel pump
Aeromotive adjustable fuel pressure regulator
Stock t5 transmission with McLeod super street clutch
Car needs some TLC. Paint, interior work (has new edge seats in it now with power drivers side) and new carpet. Speedometer does not work. Stock tach does not work it has 5" autometer tach that works. Needs brakes and front tires. It has toyo proxes drag radials on rear. Has 3.73 rear end with richmond gears and 03 cobra carrier with carbon fiber clutches. Gears do make a noise but I've never had a problem out of it. Has rebuilt title. I'm asking $5000 obo. Located in memphis, tn 20160406_173655.jpg 20170331_174105.jpg 20140927_155540.jpg 20160503_195003.jpg
No strut support or torque boxes on it. See attached pics. I dont have any pics of underneath the car. Car does have some no name sub frame connectors. Did my other pics work? 20171003_174350.jpg 20171003_174335.jpg 20171003_174350.jpg 20171003_174335.jpg
1061768
1061769
View attachment 1061637 View attachment 1061638
View attachment 1061639 View attachment 1061640
Stock block 306
JE pistons
Eagle I beam rods
Car needs some TLC. Paint, interior work (has new edge seats in it now with power drivers side) and new carpet. Speedometer does not work. Stock tach does not work it has 5" autometer tach that works. Needs brakes and front tires. It has toyo proxes drag radials on rear. Has 3.73 rear end with richmond gears and 03 cobra carrier with carbon fiber clutches. Gears do make a noise but I've never had a problem out of it. Has rebuilt title. I'm asking $5000 obo. Located in memphis, tn View attachment 1061637 View attachment 1061638 View attachment 1061639 View attachment 1061640
What do you mean by rebuilt title
Title states under remarks that it is rebuilt. Not sure why. I bought it with that title and was able to tag and insure it here in TN
1 - 8 of 8 Posts
