7521 - 7540 of 7582 Posts
The fronts are 9” wide, +26 with a 265/35. The rears are 10” wide, +20 with 285/35. I was surprised the rears fit without a ton of fender rolling and no inner fender “adjustments .” Huge thanks to Jack on em, as he was able to look at the parts I was using and set me up with offsets that worked. I merely executed it.
A little OLD SCHOOL...
CSA Maristar (I think also called Diplomat), 16x8, offset 0 or +8 (not sure anymore), 245/50 front, 255/50 rear
1055471
When I decide to go 5-lug...
American Racing Torque Thrust 2
17x8, offset +8. Tire in pic is 245/45
1055475
Stern 1 piece with a 17x8 24mm offset front. Tires are 225/45-17 Sumitomo. Rear is a 17X9 with a 39mm offset. Tires are 245/45-17 Nitto DRs.
275/40ZR17's on OEM 17x8 98 Cobra rims. You guys have to do any fender work to make them fit? I literally just stuck them on and snapped a pic, haven't looked under it yet for clearance issues. Front fenders look to be tight. Also have a set of '98 Cobra 17x8 in Chrome but the chrome isn't in great shape; they need to be refurbished but it's kind of expensive. May sell those; aint decided yet. I'm partial to the painted rims.
Sc replicas onSaleen
Stock Saleen suspension on Left, Lowered more with Full MM coil over suspension on Right without stripes (current). Non Saleen axles and 96+ spindles. MM k-member and zero offset arms.
17x9
Offset - +24mm
Backspacing - 5.95"
Weight - 23 lbs
255/40 BFG
17x10
Offset - +20mm
Backspacing - 6.30"
Weight - 24lb
275/40 BFG
Actually having them powder coated white currently....
1057618
1057617
1057616
