Any pics from the rear or side angle? Do you have any clearance issues on the inner fender (not outer, I'm sure you're fine with offsets that deep). The wheels in post #1 are just 03-04 Cobra wheels. I believe they are 17x9, 26mm offset. 6.12" backspace.My 92 coupe with a 04 IRS, MM Coil overs all around, Moda R6 wheels, 18x9 in the rear with a +45 (6.72" backspace), 18x8 in the front +45 and a 1" spacer. 275/35/18 in the rear and 245/45/18 up front.
What's the wheel specs on the blue coupe in first post?
These pics were before the Coil overs and with the old tires and no spacers on the front, but no issues with clearance, just needed to roll the rear lips cause big bumps would very slightly rub.Any pics from the rear or side angle? Do you have any clearance issues on the inner fender (not outer, I'm sure you're fine with offsets that deep). The wheels in post #1 are just 03-04 Cobra wheels. I believe they are 17x9, 26mm offset. 6.12" backspace.
