1 - 10 of 10 Posts
I have a Ford Performance Z303 camshaft that is slightly used for sale. I ended up going with a smaller camshaft when I turbocharged my stang.
Part number: M-6250-Z303
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,500-6,500
Intake Duration at 050 inch Lift 228
Exhaust Duration at 050 inch Lift 228
Duration at 050 inch Lift 228 int./228 exh.
Advertised Intake Duration 290
Advertised Exhaust Duration 290
Advertised Duration 290 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.552 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.552 in.
Valve Lift with Factory Rocker Arm Ratio 0.552 int./0.552 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible No
Sale Price: $170 shipped
Discussion Starter #2
$150 shipped
$140 shipped
$140 shipped! Buy this now....or else ;)
The idle is definitely lopey, in a good way. It isn't a huge cam by any means compared to others out there. You should have other performance modifications done to your engine in conjunction with this. Due a search on the site forum and read up on the cam some more.
$130 shipped
1 - 10 of 10 Posts
