CONGRATULATIONS!
Deepm
BBK H Pipe with Flowmaster mufflers
5 bolt Conversion(Moser rear axles and 94/95 hubs/Spindles)
Front Brake Upgrade(13 inch rotors - 4 Piston Baer Brake Kit)
Rear Brake Upgrade(Baer Iron Sport Kit - I think they are 11.65 inch rotors)
18x9 Roush Wheels
Maximum Motor Sport Camber Plates.
V3 SI-Trim Supercharger
T-Rex Fuel Pump
Trick Flow Heads twisted wedge heads with upgraded valve springs(with MLS head gaskets and APR Studs)
TFS Hardened Pushrods
Roller Rockers
Billet Timing Chain
Water Pump
Breather set up
Comp xe270hr Camshaft
Polished Valve Covers w/custom AN fittings
OEM Cobra intake
High flow fuel rails, Aeromotive regulator(with braided lines and fittings)
Ford Racing 42# fuel injectors
PMAS Velocity 95mm(Mass Air Meter)
MSD Distributor and Coil
8 Inch Crank Pulley and chrome water pump, powersteering and alternator pulleys
Anderson Power Pipe
Billet Tensionor
Tremec 3550/TKO Transmission/Bellhousing/Spec 3 Clutch/Shifter/tranny mount/driveshaft spacer
PA Front K-member w/drop mounts.
QA1 Tubular A-arms
Adjustable front coilovers
Tokiko Shocks
Ford MotorSport 65mm Throttle Body
Aluminum Drive shaft
Ford Motorsport Clutch and Clutch Quadrant
Bumpsteer kit
Quarterhorse Tuning Chip
Wideband O2 sensor
Ford Racing Aluminum radiator and Flexlite fan
Energy Engine Mounts
Polished supercharger/brackets and power steering pump
AC Delete
