the only way i would ever do this is with a new harness and not some dry rotted factory one from the 80s or 90s. i couldn't believe how dry rotted my '90 harness was when i was removing it to install my pro-m setup.I'm looking to go all in in my build and make a really clean engine bay. Any tips or metal fab that will help? Def going to paint engine bay car color. Also adding a strut tower brace.
I’m using all new DEI rewrap on my wire tuck. All new harness seems over kill.the only way i would ever do this is with a new harness and not some dry rotted factory one from the 80s or 90s. i couldn't believe how dry rotted my '90 harness was when i was removing it to install my pro-m setup.
you take that dry rotted harness (which has issues from the factory), move it around, and yes it looks better, but don't be surprised if you get some new electrical gremlins as a result.
If making a new harness would it be easier to have it all tucked in one of the front frame rails just above the k-member?the only way i would ever do this is with a new harness and not some dry rotted factory one from the 80s or 90s. i couldn't believe how dry rotted my '90 harness was when i was removing it to install my pro-m setup.
LMR Fender aprons are PERFECT thank you!The scott rod or lmr fender aprons are a must if you’re painting the bay. It’s nice to start with a clean slate
