Does anyone know where I can find this felt material or a place that sells new adjusters? This isn't your average felt. It's backed with a stitched fabric for durability.
I tried both part numbers and neither are it. Thanks for trying.These are the OEM part numbers from Ford. I believe the last photo is the up stop bracket.
22380 Door window glass inner stabilizer
21742 Front Door Window Front up stop bracket
I hope this helps
Michael Plummer
Check out this link. Roll your mouse over the second pic. See how the metal is shaped differently and has a male threaded stud? Mine has a nut attached and a bolt goes through top of door into that nut. Don't you just love these parts diagrams? I think things vary through the years for no good reason. UGH!Those are the part numbers for the 1994 Ford Mustang Service Manual. 🤷♂️🤷♂️
That's the stop with rubber pad. Can you imagine if the glass tried to glide up and down against 2 of those? I need the felt wrapped guide which seems to be unobtanium. Can you believe NPD's price on that stop?
I may but I'm sure that they are just as worn. I'm working on finding suitable replacement material. It needs to be weather resistant, durable but very soft.Time to hit a salvage yard.
