21 - 40 of 49 Posts
Vendor
Discussion Starter #27
2015-2017 Ford Mustang Front Turn Signal Assemblies by Diode Dynamics
Our new Sequential LED Turn Signals for the 15-17 Mustang are available now through our website, and through our authorized dealers! Computer-designed using optical simulation software, they add a bright, crisp white running light with a highly efficient SAE/DOT compliant beam pattern!
The turn signal is nearly twice as bright as the factory turn signal, and features a programmable sequential blink rate for a truly custom look! Available with smoked or clear lenses! #MadeinUSA
Nick C.​
Vendor
Discussion Starter #38
Measuring Headlight Output | Diode Dynamics
How are headlight output patterns measured at the factory level? How do you test to see if a headlight is meeting SAE and DOT beam pattern requirements? Here at Diode Dynamics, we've invested in a goniometer to accurately measure and map the entire beam pattern and ensure our products are adding light output without adding extra glare.
Check out the video to see how it works!
Jake H.
Diode Dynamics
21 - 40 of 49 Posts
