Had been delaying the fix for the headlight off/on flicker issue and did not print out the diagram and/or instructions because mistakenly thought it would always be here. Now, I cannot find it? I know if someone did the procedure incorrectly could create some huge issues, and perhaps that is why it was removed, but wishing perhaps it is still around here just under a different name? There is a supposed fix of just replacing the headlight switch with one of the newer upgraded versions, but the relay fix was a great permanent correction. Does anyone know where those detailed directions went?
