1 - 20 of 28 Posts
My bottom end is getting rebuilt (again) and I’m going to be upgrading heads to AFR 165’s. I have a Tmoss ported explorer intake and 65mm TB. Current cam is a xe264 but may go with a custom Ed cam if I can sell off a few parts.....if not now, will do a custom cam next year, but I need heads now as I sold my old ones.
Figuring on a conservative 300whp, my stock 19lb injectors will be a bit light. What is a good, OEM quality, reliable upgrade that won’t cost a fortune? It will be tuned for whatever I get.
Deka 80. Wouldn’t consider anything else.
X2
Yes, those would be ideal, but overkill for my modest hp, especially of I can spend a fraction of that. I guess I’m looking for the “Explorer Intake” of fuel injectors lol.
Man, this hobby is expensive.
dont play the injector game, like i did, wasted money
go directly to what works, and you wont need to replace with future HP goals
you will save money
  • Like
Reactions: Stangdawg
Thanks guys. Will keep it under consideration.
you will save money
Agreed, i have like 3 extra sets of injectors lying around! Definitely didn't save any money buying multiple times!
I would normally agree with the injector sizing, but given this combo is limited to fitting under a Miata hood, it doesn’t sound like shooting for the moon is the end goal.
I ran Accell 30lb injectors on my 347 before I upgraded.
low mount turbos is in the works
I kinda figured you were talking about buying new injectors. A good set of injectors, whether it be 24, 30, 36, 80 lb’ers are pretty much all going to set you back over $300. Might as well buy the one that’ll split stock blocks before being outgrown.
If you’re looking at used ones, just find anything 30lbs or more and buy them. It’s always kind of a crap shoot buying used ones though.
You may laugh, but my coworker stuffed a turbo LS1 under the hood of a Miata with just a "wee bit" of custom work.
Discussion Starter #13
Ya, all the cool kids are doing turbo’d LS’s in Miata’s, but an old iron block 5.0 is perfectly fine for this old geezer. Besides, Fords just sound so much better.
I’m a musician, it has got to sound good.
I have a set of the red top Motorcraft 30# injectors that were in a motor for a minute before upgrading to larger ones (347" stroker), indistinguishable from brand new. Make a reasonable offer, I'll send them your way.
Jay
I agree on the dekas. You can run such a small pulse width with them and it won't negatively affect part throttle fueling on lower hp setups like you get with most larger injectors. I run the 60s and have a bunch of room to grow.
Sorry, didn't mean to say the LS is the way to go.
My comment was more about the turbo.
If you're creative, you can squeeze a turbo 5.0 under the hood and utilize 'more' of the 80lb dekas. ;)
Discussion Starter #18
Yup, I didn’t take it as that- I knew what you were saying.......it’s Indy’s fault for bringing up turbo’s. lol
i'm one of few reasons NOT to be a member at the corral!!
1 - 20 of 28 Posts
