1 - 13 of 13 Posts
Anytime have info regarding troubleshooting cruise in 94/95 mustangs? Mine just quit working one day. I'm going to start with the basics like making sure all the pedal switched are working but i want sure if there is a specific troubleshooting procedure.
Discussion Starter #2
Oh yeah, my horn works.... So the clock spring is probably ok
Check for a vacuum leak in the hose, does you heater work I.e can you switch between floor, vent and defrost? If not, a hose on the vacuum tree is broken.
is te cable attached to your a throttle body?
Check the brake and clutch switches.
Heat works fine, everything on the vacuum tree is good. I don't think i have any vacuum leaks. I'll get under the dash and check continuity on the switches and check the vacuum switch under the dash too
Does anyone have any recommendations or even a wiring diagram regarding cruise for troubleshooting?
Moderator
I seem to remember a lot of resources in the "info lookup thread" at the top of this forum.
VeryUseful.com doesnt have anything regarding cruise diagrams and the info look up thread you are speaking of also does not have anything specific to cruise. I went through both of those as well as used the search feature before I posted this question. There is very little cruise troubleshooting info on the site
I have wiring diagrams for the whole car, but something like the Cruise Control is likely split across several pages. I also have a digital copy of the service manual. I’ll check what it has for trouble shooting.
I have wiring diagrams for the whole car, but someht8ng l8ke t(e Cruise Control is likely split across several pages. I also have a digital copy of the service manual. I’ll check what it has for trouble shooting.
im most likely going to just buy a service manual myself that way I dont have to rely on a website to try and find this info. Let me know what you find though cause it will be a while before it comes in I am sure.
I hope this helps.
1071805
1071806
1994 and early 1995 Mustangs have cruise control buttons that have (4) female leads. Late 1995 to 2004 the female leads changed from 4 to 2. I have no idea if they are interchangeable.
Good luck
Michael Plummer
  • Like
Reactions: Dwain
Thanks Michael. My car is an early 95, built in 94. Ill try to use that to work through the wiring and verify I am getting good signals past the clock spring. I installed a hydraulic clutch system from modern driveline and one of the switches got moved as part of the install. Im going to start there first. Havent had time to check it yet but im expecting to get under the dash this weekend.
Here is a photo of the cruise control switch (4 female leads) you want for 1994 Mustangs if you decide to replace it. The two different switches may be interchangeable but I haven't had a chance to confirm that.
1071807
And a closeup of the 4 female leads
1071808
Here is a photo of the 2 female leads for late 1995 to 2004 Mustangs.
1071809
I hope this helps
Michael Plummer
Here's the whole wiring layout of the cruise control circuit.
1071810
1071811
1071812
Most of the problems I've seen have come from the speed control amplifier.
Good luck
Michael Plummer
1 - 13 of 13 Posts
