I got this water pump along with a bundle of parts I bought so I have no idea what its for. I tried to cross reference any numbers I could find on it but I had no luck. It is very close to a stock 302 Foxbody pump. Please help.
The length of the snout is the same as a stock pump.
It lines up with a stock Fox timing cover.
The holes for the pulley are closer together compared to a stock pump.
It has one extra bolt hole near the lower radiator hose opening.
It has one hole blocked off on the top because of the backing plate.
The pump in question would be the more silver one with the AN fittings. Bottom is stock.
I don't see any AN fittings, but I'm assuming you mean the top one in the first pic.
Do standard and reverse rotation pumps have the same bolt pattern on the pulleys?
