Ford AOD; Solid, one-piece input shaft that requires a non-lockup converter that is an original Art Carr (Hybrid AOD/C6 input shaft with C6 style splines, Lentech valve body, chrome pan cover, Ford Racing Wide Gear Ratio:
1st: 2.84:1
2nd: 1.55:1
3rd: 1:1
O/D:2.32
Includes custom Edge torque converter. Specs were a 31 spline non lock AOD. Stall is set at 3600 rpm, and srt is 2.45.
I had this transmission rebuilt in 2018 and has less than 500 miles on it. It changed the personality of my car and it felt much more aggressive. I put my car back to stock and put the original transmission back in. I have much more invested.
Asking $1250.
Manual valve body, transbrake, where are you located?
Lentec valve body that retains automatic function if desired. It changes the shifts to 1-2-Drive with overdrive defeated with a switch if desired.
No transbrake.
Located near Pittsburgh, PA airport.
