1 - 8 of 8 Posts
Some are aware that I've been dealing with some gremlins with my car. I was told if any of the capacitors have any green fuzz below them that they are bad. Also there is another one that has greyish substance under it.
I decided to pull out the ecu to see if I have a aftermarket chip ( plan on getting tune verified) and found this kb flip chip.
I also found this ground wire that is bare, no insulation.
I also wanted to check the internals. Pretty sure it's bad, just looking for confirmation.
Any good places to buy a reman?
Sent from my Moto E (4) Plus using Tapatalk
Discussion Starter #2
Just noticed one of the capacitor legs is completely gone.
if you want to test capacitors, your other thread already told you how
if you find one with a open, replace it, and the rest if it makes you feel better.
that chip is an old relic, get yourself a tuner or tuning device, you will quickly find out, if there is an ECM issue, FOR CERTAIN, not guessing
the bare ground is normal, nothing wrong with it.
  • Like
Reactions: 91GTstroked
I have a local electronics store solder in 3 new capacitors, or you can send off ecm to have it refurbished. Probably won't be able to find a refurbished one from parts store anymore.
I'm sending it to ECU Exchange. They will have it all checked out.
I replaced the caps in my computer with no issues whatsoever. Any mediocre soldering kit will have everything you need to do the job. I did mine a couple years ago. I bought the caps and a how-to from a guy on eBay. My caps looks just as bad, if not worse. I definitely noticed a seat of the pants difference
Glad I sent it in. They found more than just the capacitors.
  • Like
Reactions: 90M7LSC
Stand up company, highly recommend. I ran the car up to operating temp. Then shut it off and did a KOEO. Code 11, followed by a 10.
Still need to see if I have a vacuum leak.
1 - 8 of 8 Posts
