Bear in mind, when you're looking at heads that the actual "design" is pretty much dictated by the application. The combustion chamber is "designed" by the sweep of the valves. The ports are where the ports are, though they can be moved a little....and you can alter the shape a bit, depending on where you put your water jackets. you put the plug as high as you can....and you're all done.
It's like people telling me they designed their pistons. You can alter the rings and lands, Compression height and the compression ration..and those are dictated. There is no "designing" involved. It's just math. As long as nothing crashes into anything else the part will work just pine.
