Since the AEM is controlling the ignition, you should not pull out the spout. With the AEM you must use the set-timing wizard and the timing on the mark should match what AEM is commanding when you bring up that tool.
If it doesn't match, use the +/- buttons in the timing wizard to sync the actual timing to the commanded timing.
