41 - 60 of 64 Posts
Discussion Starter #41
Just a solid driver side
Indiana 46375
Discussion Starter #43
No i do not
Discussion Starter #44
Bump...
Discussion Starter #45
Bump...
Discussion Starter #46
Bump....
Discussion Starter #47
Bump
Discussion Starter #49
No!!!!
Discussion Starter #50
bumppp....
Discussion Starter #51
Discussion Starter #54
stock oem 5.0 explorer egr stock bore but can be out to 65mm or 70mm a machince shop $30
stock 5.0 MAF sensor $36
BBK HIGH FLOW air filter 25
headlight switches throw me a offer
89 ford mustang 5.0 purge canister 35
oem ac/ps bracket 25
oil pan brace/bolt liner 5 for both
stock crank from a 90 ford mustang roller motor 50 journals are in great condition
k/n cone air filter has a slight burn but still function $20
accel super stock spiral wire kit bnib part# 5040R red color wires 45 pick up 60 shipped
90 5.0 aod mustang complete(firewall{no fuse box##, dash, and o2) with out engine harness for 300
^This harness has no airbags and a/c controls are deleted thru the harness.
^this harness has everything labled, very clean, and perfect for drag car/Clean look
Ford racing 31 spline output shaft for drive shaft bnib 70 pick up
90 Aod transmission with trans mount and torque converter 500
Oem manual flywheel needs to be resurfaced 40
X2 Aod flexplate oe 45 3 of a 5.0
belt tensioner 10
x2 radiator support/brackets 10 for both
ignition coil 20
ps pulley 10
front bumper from 89 mustang lx part out 175
1 5/8 steel headers mac steel equal lengh shortys 80 for both
plastic battery tray 5
ac delete bracket 25 tricflow/march
50oz harmanic balancer 35
Tci aod flexplate 157 tooth 50oz 70
Carton street/strip 7qt oil pan no pick up tube 200
93 5.0 aod engine bay/firewall and engine harness 175 with no o2
93 5.0 manual convertible complete dash harness with fuse box125
89 mustang 5.0 complete harness engine bay, fire wall and o2 harness 185 SOLD
93 302 complete engine has compression no misfire, smoke, or knocks 350
(complete engine comes with shortblock, heads, lower intake, dizzy, wp, fuel rails, 19pd injector, valve cover, dpstick, harmanic balancer/pulley, and heater core metal lines
distributor with oem tfi module and cam gear $50.00
X2 rotor and caps all from running cars 25 for both
A9p 200 no mods all stock sold
A9L 200 no mods all stock sold
75mm pro motion maf calibrated for 75mm tb and 30pds injectors 125
x2 I also have the misc for converting to maf sensor, vacuum lines, and map on the mustang lmk
5.0 HO bolt cover on upper intake manifold 25.00
fuel line $25
driver side fender 175 in great solid shape original paint but not clear white
chrome pcv cover $20
stock air inlet $30
sway bar endlink bushing 10 for both
Full part out 89 MUSTANG LX 5.0 5SPD, 5 LUG orange, Thanks lmk with email on what you are looking for.
much to add later
NO LOW BALLING PLZ I WILL NOT ANSWER and IN CHICAGOLAND AREA/INDIANA BORDER
picture of some parts are in 2 and 3 page and 4 page more soon
I'd like the oil pan rails. PM me your paypal, venmo or cashapp and total price shipped to 12414 and I'll get payment sent ASAP.
Discussion Starter #56
Discussion Starter #59
yes it is
@stangklick Do you have the smaller heater box bracket available? It's the one on the left if you're looking at the dash. There a longer curved on on the right then a shorter straight one. I've seemed to have misplaced mine. Let me know if you do and how much you want for it.
41 - 60 of 64 Posts
