1 - 20 of 64 Posts
Stock Oem 5.0 explorer egr spacer stock bore at 65mm size $35
Ford Racing 5.0 MAF sensor calibrated for 24pd injectors and 70mm tb
BBK HIGH FLOW air filter 25
headlight switches throw me a offer
89 ford mustang 5.0 purge canister 35
oem ac/ps bracket 35
Stock Oem cast 5.0 HO crank shaft from a 90 ford mustang. The crank journals are in great condition.
k/n cone air filter has a slight burn but still function $20
accel super stock spiral wire kit bnib part# 5040R red color wires 45 pick up 60 shipped
90 5.0 aod mustang complete(firewall{no fuse box##, dash, and o2) with out engine harness for 300
^This harness has no airbags and a/c controls are deleted thru the harness.
^this harness has everything labled, very clean, and perfect for drag car/Clean look
Ford racing 31 spline output shaft for drive shaft bnib 70 pick up
Oem manual flywheel needs to be resurfaced 40
X2 Aod flex-plate Oem 45 3 of a 5.0
belt tension er 15
x2 radiator support/brackets 15 for both
ignition coil 25
ps pulley 15
front bumper with bumper support from 89 mustang lx part out 150.00
plastic battery tray 15
Ac delete bracket 25 tricflow/march
50oz harmanic balancer 50
Tci aod flexplate 157 tooth 50oz 70
Carton street/strip 7qt oil pan no pick up tube 200
93 5.0 aod engine bay/firewall and engine harness 175 with no o2
93 5.0 manual convertible complete dash harness with fuse box 125
89 mustang 5.0 complete harness engine bay, fire wall and o2 harness 185 SOLD
91 302 complete engine has compression, no misfire, smoke, or knocks 450
(complete engine comes with shortblock, heads, lower intake, dizzy, wp, fuel rails, 19pd injector, valve cover, dip-stick, harmonic balancer/pulley, and heater core metal lines
distributor with oem tfi module and cam gear $50.00
X2 rotor and caps all from running cars 25 for both
76mm pro motion maf calibrated for 75mm tb and 30pds injectors 125
x2 I also have the misc for converting to maf sensor, vacuum lines, and map on the mustang lmk
5.0 HO bolt cover on upper intake manifold 25.00
fuel line $25
driver side fender 175 in great solid shape original paint but not clear white
chrome pcv cover $20
stock air inlet $30
sway bar endlink bushing 10 for both
Full part out 89 MUSTANG LX 5.0 5SPD, 5 LUG orange, Thanks lmk with email on what you are looking for.
much to add later
NO LOW BALLING PLZ I WILL NOT ANSWER and IN CHICAGOLAND AREA/INDIANA BORDER
stock oem 5.0 explorer egr stock bore but can be out to 65mm or 70mm a machince shop $30
stock 5.0 MAF sensor $25
89 ford mustang 5.0 purge canter
oem ac/ps bracket 25
oil pan brace/bolt liner 5 for both
stock crank from a 90 ford mustang roller motor 50 journals are in great condition
90 Aod transmission with trans mount and torque converter 500
Aod flexplate oem 35 of a 5.0
belt tensioner 10
x2 radiator support/brackets 10 for both
ignition coil 15
ps pulley 5
front bumper from 89 mustang lx part out 175
1 5/8 steel headers 40 for both
plastic battery tray 5
ac bracket 10
50oz harmanic balancer 25
93 5.0 manual convertible complete dash harness with fuse box125
93 302 complete engine has compression no misfire, smoke, or knocks 350
(complete engine comes with shortblock, heads, lower intake, dizzy, wp, fuel rails, 19pd injector, valve cover, dpstick, harmanic balancer/pulley, and heater core metal lines
A9p 150 no mods all stock
A9L 150 no mods all stock
75mm pro motion maf calibrated for 75mm tb and 30pds injectors 125
5.0 HO lower intake manifold very clean just need the coolant line rethreading 30 obo
fuel line $25
stock air inlet $30
sway bar endlink bushing 5.00
much to add later
EVERYTHING IS BEST OFFER, NO LOW BALLING PLZ I WILL NOT ANSWER and IN CHICAGOLAND AREA/INDIANA BORDER
Looking for a WC T5 transmission, how much and where are you located?
Still have the a9l or a9p and how much?
Discussion Starter #16
Bump....
Discussion Starter #17
I also need oem valve cover from a 5.0 Hi
Will buy or trade from my part collection thanks.
Discussion Starter #20
Pm me your guys number k
1 - 20 of 64 Posts
