1 - 9 of 9 Posts
1998 Ford Mustang gt
What is the coil pack ohm specs for a 98 mustang gt I want to know the primary and secondary specs
Discussion Starter #2
On the driver side coil pack The secondary read 15.24 and passengers side it read 14.14
ohm specs will be determined by temperature, so its a useless metric
if you dont want to go through the scope route, as that is the only way to tell, as you will compare waveform with a good known
just ensure you are using genuine FORD packs
I am use a voltagemeter to test it the msd supposed to be 13.7 ohm but while sitting my car read 14.37 on the pass side and 15.37 on the driver side
When the car is warm up on the pass side it go to 15.27 ohm and driver side it go to 16.35 ohm
1 - 9 of 9 Posts
