All you changed here are the axles, correct?
Assuming the axles are 28 spline, the button thickness should be 0.249". The groove width in the axle should 0.167" wide. Many aftermarket axles are machined incorrectly.
Don't grind on anything. Just use some old friction discs to slightly reduce the overall thickness of each of the clutch packs. This is one of the good reasons to keep all of the old discs.
