anyone heard of this being done? yes I know its gonna break it but I still wanna do it! is there a bellhousing swap or??
plz help:leghump:
you can use a standard regular bellhousing for a toploader and then bolt on an adapter plate to make thebolt pattern and input shaft length work out.
there are only two T-5 transmissions that have the proper spine length and shaft diameter. because there were a zillion more that were in 4 cylinder and 6 cylinder applications and the input shaft is different.
even the better ones will split in two behind a 460.
the other major set-up thing is how to operate the clutch fork.
mcleod makes now a three piece bellhousing that has the rear face plate that has the proper bolt pattern on it.
A regular T-5 out of any 5.0 mustang is very universal, and it shares the same shaft specs as a TKO600. The 2 trannys also use the same bolt pattern except one bolt, so either have the old hole filled and drill a new one for the T-5 or get the adapter he is talking about. youll need a spacer anyways because the toploader bells are one inch shorter and so the toploader had a one inch shorter shaft.
I am running a TKO600 behind a 460 right now and the install is exactly the same as a T-5 except for that one bolt hole difference I was talking about. You will not need to modify your driveshaft, V8 double hump crossmember or the original clutch cable. It all bolts right up.
You better get the thing beefed up if you want it to survive. G-Force would be a good bet.
Quicktime makes a bellhousing to do a t-5 behind a 460
