The two intakes I know will fit are the CHI 3V single plane air gap
and the Scott Cook low rise dual plane (externally very similar looking
to a Ford dual plane). I'm running a 351C dyno project with Dave
McLain and we've flow bench and dyno tested the CHI 3V and Pro Comp
heads, along with unported iron 4V heads. We still have a bunch of
heads to test but I've posted some results below that may be of
interest. The short block in the tests below was a simple
street 351C with flat top TRW forged pistons and a mild hydraulic
roller cam with specs of:
228/232 degrees at 0.050" lift (280/284 at 0.006"), 0.588"/0.588" lift,
107 LSA, 68 degrees overlap, installed in the engine on a 104 intake
centerline.
Later we'll be testing 393C and 408C short blocks. Even on the relatively
mild 351C street engine, the CHI heads were worth nearly 50 HP (48.5 HP at
6000 RPM to be exact) through the mufflers in back-to-back tests compared
to the Pro Comp heads.
I found it interesting that the CHI single plane intake gave up nothing
to the dual plane anywhere in the RPM band tested while picking up the
expected 20 HP on the top end. I'm an aerospace engineer with an aerodynamics
background and the CHI plenum is designed the way I've always thought a
plenum should be with blunt rounded edges. Subsonic flow responds best
to blunt rounded edges (think of the rounded nose and thick wings of a
Boeing 747 aircraft) while supersonic flow prefers thin sharp edges
(think of the pointy nose and thin wings of a Concorde supersonic
transport). Many 351 Cleveland single plane intakes have relatively sharp
dividers between the ports. I remember discussing the CHI single plane
intake with Jon Kaase. He said he spent a lot of time modifying a Yates
single plane NASCAR intake to match the CHI heads thinking it would give
him an edge in the Engine Masters Competition, only to find the CHI single
plane out-performed it out of the box. Be aware the CHI intake is very tall.
Given the Scott Cook low rise dual plane only gave up 20 HP or so to the
CHI, I think it did very well.
We've also test unported iron 4V closed chamber Cleveland heads (ported heads
will also be tested at a later date). With a Strip Dominator intake on the
4V heads, they bested the Pro Comps by around 30 HP but wer down around 20 HP
to the Pro Comps.
Dan Jones
6500 rpm test 4V Boss
Gave the engine more timing still, 37 degrees max. Same as previous pull with
37 degrees timing. Took engine to 6500rpm just to see and it runs the same as
at 5700rpm Good solid pull but engine is done at about 6200 just like before.
RPM HP Torque (ft-lb)
4000 299.5 388.8
4100 302.3 388.5
4200 310.8 388.4
4300 321.4 392.8
4400 328.4 392.3
4500 338.3 394.7
4600 349.0 398.4
4700 359.3 401.5
4800 367.8 402.5
4900 375.3 402.2
5000 382.1 401.0
5100 388.4 400.1
5200 396.8 400.6
5300 403.1 399.7
5400 407.5 396.2
5500 413.4 394.7
5600 415.5 390.1
5700 409.6 377.6
5800 406.0 367.6
5900 407.6 362.5
6000 406.7 356.3
6100 410.0 352.8
6200 415.2 352.1
6300 417.0 347.6
6400 418.7 343.8
CHI Heads with CHI single plane intake (4150 flange) and HVH spacer.
Best combination for CHI heads
RPM HP Torque
3200 222.0 359.8
3300 222.4 354.8
3400 230.3 356.0
3500 240.0 360.3
3600 249.9 364.9
3700 262.0 371.8
3800 277.0 382.4
3900 293.2 394.4
4000 302.8 397.8
4100 315.7 404.3
4200 329.8 412.1
4300 341.1 416.5
4400 349.7 417.9
4500 357.7 417.5
4600 369.2 421.2
4700 377.5 422.1
4800 386.2 422.4
4900 394.5 422.9
5000 401.7 422.1
5100 411.6 423.7
5200 420.5 424.8
5300 428.3 424.6
5400 436.2 423.4
5500 434.2 415.1
5600 431.2 404.6
5700 430.8 396.8
5800 432.4 391.9
5900 433.2 385.7
6000 435.6 381.5
6100 435.1 374.4
The numbers posted here are corrected to Std Day atmospheric conditions and
through a full exhaust (some mufflers lost 50 HP!). With a bit more timing
I think the peak was just under 450 HP but we had some detonation at low
RPM. Rather than re-curving the distributor we pulled back on the total
timing. A later test with a shorter rocker 1.65:1 ratio on the exhaust
picked up torque (as much as 13 ft-lbs at lower RPM) but made about the same
peak HP.
On the same night as the Pro Comp tests, here's what the CHI 3V heads and
intake pulled. At 6000 RPM, the Pro Comps were down 48.5 HP.
RPM HP Torque
3200 219.2 359.1
3300 218.7 348.6
3400 225.8 348.7
3500 236.4 354.6
3600 247.4 361.1
3700 259.5 368.2
3800 273.9 378.1
3900 287.4 386.8
4000 298.6 392.3
4100 309.2 396.4
4200 320.1 400.4
4300 332.0 405.4
4400 343.8 410.3
4500 355.3 414.6
4600 367.3 419.1
4700 374.7 418.2
4800 375.8 411.8
4900 382.8 410.1
5000 392.1 412.0
5100 406.5 417.7
5200 410.3 414.9
5300 419.7 415.8
5400 427.5 415.5
5500 432.8 412.9
5600 429.1 403.0
5700 425.7 392.4
5800 421.7 381.9
5900 423.0 376.4
6000 428.5 375.3
6100 428.3 368.3
Pro Comp Heads with CHI single plane intake (4150 flange) and HVH spacer.
Best combination for Pro Comp heads
RPM HP Torque
3000 198.8 347.2
3100 202.8 343.7
3200 212.2 348.3
3300 218.6 348.1
3400 224.5 347.1
3500 234.2 351.3
3600 247.4 360.3
3700 258.7 367.5
3800 268.1 370.5
3900 279.4 376.0
4000 291.7 382.9
4100 303.6 388.8
4200 315.7 394.6
4300 328.4 401.0
4400 334.2 399.4
4500 339.2 396.1
4600 346.6 395.6
4700 361.1 402.5
4800 368.6 403.5
4900 374.7 401.5
5000 376.8 396.2
5100 379.9 391.1
5200 385.1 388.8
5300 388.9 385.4
5400 393.4 382.5
5500 396.7 378.6
5600 396.3 371.6
5700 391.2 360.7
5800 387.7 351.0
5900 384.1 342.2
6000 380.0 332.5
6100 384.5 330.6
CHI 3V Heads and Scott Cook Dual Plane Intake
1 inch open spacer and 34 degrees timing.
RPM HP Torque
2500 151.3 319.2
2600 157.1 317.3
2700 165.2 321.5
2800 173.9 326.4
2900 184.2 333.3
3000 193.6 338.8
3100 201.8 342.0
3200 209.3 343.5
3300 219.6 349.7
3400 233.0 359.8
3500 245.2 367.9
3600 257.5 375.5
3700 271.6 385.2
3800 285.5 394.6
3900 299.3 402.9
4000 312.9 410.6
4100 325.5 417.0
4200 334.0 418.1
4300 341.3 416.9
4400 350.7 418.3
4500 359.8 419.8
4600 369.8 421.7
4700 378.3 423.6
4800 383.0 419.4
4900 388.3 416.1
5000 394.6 414.4
5100 401.8 413.5
5200 408.7 412.9
5300 415.4 411.6
5400 416.7 405.1
5500 416.7 398.3
5600 415.3 389.2
5700 414.1 381.9
5800 414.4 375.3
5900 419.0 372.9
6000 418.8 366.7
centerline.
to the Pro Comps.
Dan Jones
4000 299.5 388.8
4100 302.3 388.5
4200 310.8 388.4
4300 321.4 392.8
4400 328.4 392.3
4500 338.3 394.7
4600 349.0 398.4
4700 359.3 401.5
4800 367.8 402.5
4900 375.3 402.2
5000 382.1 401.0
5100 388.4 400.1
5200 396.8 400.6
5300 403.1 399.7
5400 407.5 396.2
5500 413.4 394.7
5600 415.5 390.1
5700 409.6 377.6
5800 406.0 367.6
5900 407.6 362.5
6000 406.7 356.3
6100 410.0 352.8
6200 415.2 352.1
6300 417.0 347.6
6400 418.7 343.8
RPM HP Torque
3200 222.0 359.8
3300 222.4 354.8
3400 230.3 356.0
3500 240.0 360.3
3600 249.9 364.9
3700 262.0 371.8
3800 277.0 382.4
3900 293.2 394.4
4000 302.8 397.8
4100 315.7 404.3
4200 329.8 412.1
4300 341.1 416.5
4400 349.7 417.9
4500 357.7 417.5
4600 369.2 421.2
4700 377.5 422.1
4800 386.2 422.4
4900 394.5 422.9
5000 401.7 422.1
5100 411.6 423.7
5200 420.5 424.8
5300 428.3 424.6
5400 436.2 423.4
5500 434.2 415.1
5600 431.2 404.6
5700 430.8 396.8
5800 432.4 391.9
5900 433.2 385.7
6000 435.6 381.5
6100 435.1 374.4
peak HP.
RPM HP Torque
3200 219.2 359.1
3300 218.7 348.6
3400 225.8 348.7
3500 236.4 354.6
3600 247.4 361.1
3700 259.5 368.2
3800 273.9 378.1
3900 287.4 386.8
4000 298.6 392.3
4100 309.2 396.4
4200 320.1 400.4
4300 332.0 405.4
4400 343.8 410.3
4500 355.3 414.6
4600 367.3 419.1
4700 374.7 418.2
4800 375.8 411.8
4900 382.8 410.1
5000 392.1 412.0
5100 406.5 417.7
5200 410.3 414.9
5300 419.7 415.8
5400 427.5 415.5
5500 432.8 412.9
5600 429.1 403.0
5700 425.7 392.4
5800 421.7 381.9
5900 423.0 376.4
6000 428.5 375.3
6100 428.3 368.3
RPM HP Torque
3000 198.8 347.2
3100 202.8 343.7
3200 212.2 348.3
3300 218.6 348.1
3400 224.5 347.1
3500 234.2 351.3
3600 247.4 360.3
3700 258.7 367.5
3800 268.1 370.5
3900 279.4 376.0
4000 291.7 382.9
4100 303.6 388.8
4200 315.7 394.6
4300 328.4 401.0
4400 334.2 399.4
4500 339.2 396.1
4600 346.6 395.6
4700 361.1 402.5
4800 368.6 403.5
4900 374.7 401.5
5000 376.8 396.2
5100 379.9 391.1
5200 385.1 388.8
5300 388.9 385.4
5400 393.4 382.5
5500 396.7 378.6
5600 396.3 371.6
5700 391.2 360.7
5800 387.7 351.0
5900 384.1 342.2
6000 380.0 332.5
6100 384.5 330.6
RPM HP Torque
2500 151.3 319.2
2600 157.1 317.3
2700 165.2 321.5
2800 173.9 326.4
2900 184.2 333.3
3000 193.6 338.8
3100 201.8 342.0
3200 209.3 343.5
3300 219.6 349.7
3400 233.0 359.8
3500 245.2 367.9
3600 257.5 375.5
3700 271.6 385.2
3800 285.5 394.6
3900 299.3 402.9
4000 312.9 410.6
4100 325.5 417.0
4200 334.0 418.1
4300 341.3 416.9
4400 350.7 418.3
4500 359.8 419.8
4600 369.8 421.7
4700 378.3 423.6
4800 383.0 419.4
4900 388.3 416.1
5000 394.6 414.4
5100 401.8 413.5
5200 408.7 412.9
5300 415.4 411.6
5400 416.7 405.1
5500 416.7 398.3
5600 415.3 389.2
5700 414.1 381.9
5800 414.4 375.3
5900 419.0 372.9
6000 418.8 366.7
