I have a 62 Ford Falcon with a 331 stroker in it. I purchased the car with the engine already installed. I’d like to add nitros to the mix but I have no specifications on the build. Is there a way to determine what I have without tearing it down? It was built in the Charlotte n.c. area by a builder who has since gone out of business. Any help is greatly appreciated.
Pull the oil pan. You might be able to see the part number of the piston and maybe the rods. What heads are on it? That will give you a clue to how it was built. Otherwise good luck.
