I picked up a 2004 Mach 1 even if it is a driver I would like it to look good so,,,,
If I run 275 40 17 on a 10.5 wheel on the back would I have any problems with the tires rubbing?
Note When I got the car two of the stock
wheels were bad. I was thinking of running two of 10.5 wheels
from asf that look like stock only wider. I checked the tire wheel chart and it said a 10.5 would
be a good match for the 275.
So will they rub when the car is loaded? Right now it has aftermarket wheels and spacers
and I don't much care for that look
